I am vbulletin site owner that down for 6 years.
im trying to upload it but since it was down, i don't have the site domain anymore so i bought a new one.
now im dealing with those issues:
- php Apache version.
- old mods
- different database name
- different URL
in order to try to solve the problem, i uploaded the database via ssh (big database) and in it i run the queries:
update setting set value = 'http://wew.co.il where varname='bburl';
delete from datastore where title in ('options', 'publicoptions', 'miscoptions');
and i uploaded all of the files into public html.
now, because my mods are old, i put in config.php under <?php:
define('SKIP_ALL_ERRORS', true);
define('DISABLE_HOOKS', true);
i downloaded the last version of the system, put into upload/install the tools.php file and deleted the install.php
and then uploaded all the upload files to my public_html as well.
i couldt access it so i run the upgrade via ssh: php -f upgrade.php
and it's done.
why aint working
thanks!
edit: forgot to mention, i did modify my config.php.
- old mods
- different URL
and it's done.
why aint working
thanks!
