hello i want to force read thread again for all my users.
but i saw for force read again its too much difficult and risky to do...is there any simple way to re-force thread again please glen?
please do it in simple way for us.thank you glen
==================== If you enabled this mod and forum members are being forced to read the designated topic and then later on you decided you want to reset everything so that ALL members need to be forced to read the topic again, then you can do so by executing the below SQL queries to quickly update the database directly. DISCLAIMER: ----------- Do this at your own risk. vBMods.rocks is not responsible for data loss or broken site as a result of this. It is highly recommended that you back up the database first before executing the SQL queries. UPDATE userfield set fieldX='' where fieldX='Yes'; Add table prefix you are using to the table (if any). For example, if table prefix is "vb_", then use vb_userfield Change fieldX to the corresponding profile field ID of the Force Read flag noted in Step I.6. For example: UPDATE vb_userfield set field6='' where field6='Yes'; If you want to only reset the Force Read flag for a specific user: (Change xxxx with the corresponding user id) UPDATE vb_userfield set field6='' where field6='Yes' AND userid=xxxx; If you want to reset the Force Read flag for multiple users: UPDATE vb_userfield set field6='' where field6='Yes' AND userid IN (123, 456, 789); ====================
