Menus does not get change in German Language
    Hello,
    I have added navigation bar in my menus I have install 2 languages in my forum english and german when my forum is translated into english then I can see the name of the navigation bar which I have changed.
    But when my forum is translated is translated into German then by-default I can see the by-default name only which was there previously when I have not change the name
    for eg. Translating to English I can see :
    While the forum is translated into German then the name which was there when I installed the metro theme
    Could you please help me why in both the languages I cannot see the same name in English as well as in German
    There is a phrase for each navbar icon. Just search for navbar_. You have to enable "Phrase Variable Name Only" and could set phrase-Type to "Navbar Links".
    My forum closed !
      Thank You!!! It worked perfectly.
        please also suggest me how to change the icon of it.
        I have to change the icon of this.
        I am using metro theme does anyone know how to change the icon of this.
        • delicjous
          Sorry, I don't know the style.
        You need to contact the theme developer to change the icons. There are a number of CSS changes needed. They are also using SVG sprite icons.
          Okay thank you
