So ive got this custom style that I've uploaded into my new forum and have been tweaking some styles and what not. For the life of me, I can't figure out where to go to edit the border on these customicons. Also when i hover over them I get that same purple color. For a custom template like this, do I need to be looking somewhere outside of stylevars to edit the color scheme? Thanks
Issue with border/hover
So ive got this custom style that I've uploaded into my new forum and have been tweaking some styles and what not. For the life of me, I can't figure out where to go to edit the border on these customicons. Also when i hover over them I get that same purple color. For a custom template like this, do I need to be looking somewhere outside of stylevars to edit the color scheme? ThanksTags: None
I assume whoever created that theme didn't create stylevars for those icons. If that is the case, then you have to tweak the style using css_additional.css template.Helpful? Donate. Thanks!
Why do you have HTML tags in the CSS? Are you sure that's the css_additional template? It looks like the template for the icons itself.Helpful? Donate. Thanks!
by matoseHi guys,
Just migrated to vB Cloud and found your forum searching for some customizations.
Nice to meet you!
m...05-03-2024, 01:25 AM -
Reply to Quick Topic Moderationby glennrocksvbCheck core/vb/api/node.php and find the closeNode function. If you are using the compressed PHAR version of the vB5 package, you will not see the api...05-03-2024, 12:00 PM
