CSS issue, or something else?
    I recently upgraded one of my sites to 5.4.3 and notice the edge on the landing page and "our members" page doesn't have a smooth/even side in the upper left corner.
    The page can be seen here.
    The opposite corner on the right might be the same way, but is hard to discern with the color. Since Its not on all pages I would think it is not a css issue.
    I'll take a look on desktop. I'm on my phone right now.
      I checked and saw the issue. But I haven't figured out yet how to fix it. Will post when I solve it.
        Thank you, Glenn.
          NumNum, try this.
          If you are on vBCloud:
          .l-desktop #channel-tabbar {
              max-width: 1198px;
          If self-hosted:
              max-width: {vb:math {vb:stylevar wrapper_max_width} - 2};
          The 2nd one is better as it's dynamically calculated off the wrapper_max_width value but having template logic is only available on self-hosted. For vBCloud you have to hardcode it and subtract 2 from wrapper_max_width value which you currently set as 1200px. If you change the stylevar value in the future, you'd also have to change 1198px to the corresponding value.
            That did the trick, thank you.
            Some coffee on the way.
              Thanks! ☕☕
