Hello. I know just enough about CSS to do simple adjustments to my board, but this one has been killing me for a week. On mobile, the quote button becomes a drop down menu. Is there anyway I can just make it a quote button where there is just one step needed to quote instead of two steps?
I haven't tried this but try adding a Replacement Variable in AdminCP > Styles > Replacement Variable Manager. Click the [Add New Replacement Variable] link for the target theme/style. Fill out the form with these values and then click Save. Repeat for all active themes/styles you are using.
Yes it worked in that it showed a quote button, but the button would not place the text in the reply box. It would scroll down and everything was good except it wouldn't place the text for some reason.
Good Day Glenn!! I implemented the above hook #1-#10. My font style and size changed when typing a reply to a post. Not sure if it also changed in other...
