G'day all,
Except for the Home Page Meta Description is there anything else I should be doing to enhance the SEO. I have usually added a Google Link to the heading of previous web sites but don't know if that is possible with AusGardenForum which is vB Cloud hosted.
Thanks and cheers
Mac
PS: I have been through the XML Site Map build and submit procedure.
PPS: I have also discovered that I cannot upload a Google HTML file through the Cloud File Manager. So my site is invisible to the world as vB appears not to be uploading the .XML Site Map.
Thanks and cheers
Mac
