Hello Glen,
I need a Maximize icon in my Advanced editor's toolbar in vBulletin Connect 5.6.7. As vBulletin 5 uses CKEditor 4 for its Advanced editor, there is a ready-made maximize plugin available on the CKEditor website. However, vBulletin 5 uses a proprietary method for implementing plugins in CKEditor so I couldn't get it to work.
The screenshot below shows a CKEditor 4 instance configured with the Maximize icon in its toolbar. It's the 2nd icon from the right. Clicking the icon results in the editor resizing to full screen. Clicking the icon again in full screen mode returns the editor to its previous windowed state. It is default CKEditor maximize plugin behavior. I need this Maximize button on all CKEditor instances throughout vBulletin Connect 5.
Can you implement this for me? If you send me your quote and how you want to be paid then I can decide quickly. Preferably this would be implemented as an installable mod. If that's impractical then I'll settle for replacement files or a detailed instruction on how to do this myself.
I have no problem with editing core vBulletin files even if that implies that I would need to re-apply the modification after every vBulletin update. I need to be able to compose/edit posts & articles full screen.
Awaiting your reply,
Regards,
--limerick
Regards,
--limerick
