Greetings,
I was wondering if, on Vbulletin, you could do the following :
1. Pick a RPG (or Dice) roll "set" : Set 1, 2, 3 [...]
2. Roll the Dices
- If Set1 was chosen, user will see the admin-customizable (not only numbers) result of the roll : Result1, or Result2, or Result3
- If Set2 was chosen, user will see the admin-customizable (not only numbers again) result of the roll : Result4, or Result5, or Result6
and it goes on
Is it any possible ? I can't code it all by myself btw.
Thanks.
2. Roll the Dices
and it goes on
Thanks.
