How to get real visitor IP address in vBulletin when using CloudFlare or Sucuri
  • How to get real visitor IP address in vBulletin when using CloudFlare or Sucuri
    Cloudflare and Sucuri act as a reverse proxy for sites using their service, which means that all of the visitor IPs will show as theirs. So if you are on the Who's Online page, you will see CloudFlare/Sucuri IP addresses instead of the actual visitor IPs. If you got spammers on your site, you wouldn't be able to ban their IP addresses, otherwise, you would ban the CloudFlare/Sucuri IPs.
    To resolve this, vBulletin 4.2+ and 5.1.9+ have a Reverse Proxy IP feature that can be easily configured in config.php file.
    Using an FTP client (e.g. FileZilla) or cPanel File Manager, navigate to the config.php file and edit it. For vB5, the file is located at <forum root directory>/core/includes/config.php. For vB4, it is located at <forum root directory>/includes/config.php.
    Scroll down to the Reverse Proxy IP section. Below is a snippet of this section:
    PHP Code:
    /* #### Reverse Proxy IP ####
    If your use a system where the main IP address passed to vBulletin is the address of a proxy server
    and the actual 'real' ip address is passed in another http header then you enter the details here */
    /* Enter your known proxy servers here. You can list multiple trusted IPs separated by a comma.
    You can also use the * wildcard (at the end of a definition only) or use the keyword 'all' to represent any ip address.*/
    //$config['Misc']['proxyiplist'] = '127.0.0.1, 192.168.*, all';
    /* If the real IP is passed in a http header variable other than HTTP_X_FORWARDED_FOR, then you can set the name here; */
    //$config['Misc']['proxyipheader'] = 'HTTP_X_FORWARDED_FOR';
    As you can see, the settings are commented out (has // in front). This means that those settings are ignored. To enable them, you have to remove the // and then change the values accordingly.
    For vB5, you can use the keyword 'all' in the 'proxyiplist' setting and you don't have to enumerate all the CloudFlare/Sucuri IP addresses. You can also use IP ranges. But I prefer using the 'all' keyword so I don't have to maintain the IP list which can get updated. This is what I did here on this site.
    For vB4, I believe you have to specify the list of all CloudFlare/Sucuri IP addresses. No IP ranges or 'all' keyword.
    Link to the CloudFlare IP addresses:
    This page is intended to be the definitive source of Cloudflare’s current IP ranges.
    Link to the Sucuri IP addresses (scroll down to vBulletin 4.2+)
    For rhe 'proxyipheader' settings, you can keep the default proxyipheader value 'HTTP_X_FORWARDED_FOR' for CloudFlare. If that doesn't work, then use 'CF-Connecting-IP'.
    For Sucuri, use 'HTTP_X_SUCURI_CLIENTIP'.
    To summarize:
    CloudFlare (vB5): (this is what I used on this site)
    PHP Code:
    $config['Misc']['proxyiplist'] = 'all'; // or use the IP addresses in https://www.cloudflare.com/ips/
    $config['Misc']['proxyipheader'] = 'HTTP_X_FORWARDED_FOR'; // or use 'CF-Connecting-IP'
    CloudFlare (vB4):
    PHP Code:
    $config['Misc']['proxyiplist'] = '<use the CloudFlare IP addresses>'; // IP addresses in https://www.cloudflare.com/ips/
    Sucuri (vB5):
    PHP Code:
    $config['Misc']['proxyiplist'] = 'all'; // or use the IP addresses in https://kb.sucuri.net/firewall/Troubleshooting/same-user-ip (scroll down to vBulletin 4.2+)
    $config['Misc']['proxyipheader'] = 'HTTP_X_SUCURI_CLIENTIP';
    Sucuri (vB4):
    PHP Code:
    $config['Misc']['proxyiplist'] = '<use the Sucuri IP addresses>'; // IP addresses in https://kb.sucuri.net/firewall/Troubleshooting/same-user-ip (scroll down to vBulletin 4.2+)
    • dhemo
      It was very useful thanks for sharing
      درمان هموروئید
    • carl4466
      Thanksss!!!!!
    • CorinthiansESC
      Thanks for sharing this.
      Was looking for a solution
    • Kathie Marmolejos
      It is interesting to read your blog post and I am going to share it with my friends.
    • Forumboy
      Nice work, Thank you
    You must be logged in to post a comment.
