vB5 AutoLinker
    Yes it works in 5.4.1. Fleiding's forum has it and it is in 5.4.1.
    I don't understand the second question. Can you please provide more details?
      autolinker basically works like i preset word/words to be linked right?
      if i have the word - "you" to be link to www.vbmods.rock then i have another phrase "thank you" that i want to link to www.vbmods.rock/forum.
      "thank you" link to www.vbmods.rock/forum? and the word "you" wont be link to www.vbmods.rock?
      • NumNum
        NumNum commented
        Two separate words two separate links? If so it should be possible as long as they are two separate lines in the admincp.
      #48
      take for example. i got 2 separate business entities (a & b). business entity A wants the word arts. business entity wants the phrase fine arts. so how do i configure it so that entity B has priority over the word "arts". is this possible first
        You should set the one with the longer words or phrases first. So do "fine arts" first then "arts". That exact scenario is explained in the settings page.
          so it is possible to link finearts to www.finearts.com
          and
          fine to www.fine.com
          and
          arts to www.arts.com right?
          • NumNum
            NumNum commented
            Give it a try and test it.
            Yes that's possible. List fine arts first then the the other words.
          #51
          how do i try it?
            If you already have the mod installed just add those to your config in the admincp. If it works, great. If not you can always delete them.
              I have yet to install. like to check what can be done before purchase
                Hey Glenn,
                I have this issue that if any of my keywords are present in an URL it also converts this to a link and therefore displaying the rest of the URL as regular text. This is the case for both HTML and BBCode embedded links.
                Let me know if you need more info!
                Rob
                  Can you post or PM a link to a sample thread with the issue?
                • Fleiding
                  Fleiding commented
                  Please see this thread. The word "aangekondigd" should be the URL and the keywords are "Groudon" and "Kyogre".
                  You have the unreleased and non-fully tested version of the mod. I sent it that version to you before to test the fix I made for umlauts. Can you try with the original version of the mod? I believe in the orginal version, it is only converting text and not existing links in a post.
                • Fleiding
                  Fleiding commented
                  I reverted to the original version, but unfortunately it didn't resolved the issue.
                  Oh ok. I'll take a look
                #55
                Is there a work around for instances when you create a post, but dont want to have the word hyperlinked because it is not used in the same context as the hyperlinked word?
                I.E. I have a link for the word "Health" that is linked to a policy. But if I use the word in a different context, such as talking about someones health, I don't want it to link to the policy. I think i know the answer, but thought I'd ask.
                  As you may have expected, this is not possible as the script has no AI to know the context. Even smart speakers such as Google Home or Alexa may not know the context in your given example.
                #56
                Thank you. I’ll just need to be crafty with my script.
                  is this mod branding free?
                    Yes. There's no branded version of this mod.
                  #58
                  can this append to links submitted by users?
                  If they a users posts a link to a widget on amazon, can I append my tracking-id to it?
