Okay, here is what I got, since I posted the thread BEFORE I installed the open graph, it wouldn't work on that one. But I just posted a new thread post and it worked fine, I am rechecking it now. I will update you.
Open Graph Meta Tags for Facebook and Twitter and all social media sites
Twitter and Facebook cache the shared URLs. It means when you share a URL, they cache it on their server in order to load the shared posts faster. You need to bust the cache in the debugging tool I linked in the instructions.Helpful? Donate. Thanks!
There is a file Installation.txt included in the zip file and it contains "Debugging Tools for Facebook and Twitter crawlers" section.Helpful? Donate. Thanks!
Did you open that "Installation" file. Your Windows is configured to not display the file extension, that's why you don't see the ".txt" extension.Helpful? Donate. Thanks!
Glenn,
This feature appears to have stopped working on my site. Not the default image, but any image embedded into a post, where it should grab that image and use it in the shared post.
Any idea where to start looking to identify the cause?
Inspect the page using the browser dev tools and check the <meta property="og:image" .../>
inside the <head>. Is the image url pointing to the correct image in the post? If yes, then the mod is working as designed. Did you add the attached image to the post recently? Social media sites cache the shared pages for faster performance. You need to bust their cache to see the updated info. I specified the links to the FB and Twitter cache tool in the instructions provided with this mod.
It wasn't.
I even did a totally new entry with a new image, same issue.
Glenn,
see what happens when you post this - http://schollloj.com/forum/the-coffe...mods-that-rock
privately on your fb wall.
No image shows up on FB because FB has a minimum dimensions of 200x200 required. My avatar which you attached in the post is only 100x100. I mentioned this FB requirement in the instructions for this mod.
Have you fixed this issue yet? Aside from the FB limitation on file size, having 8MB image is not good for your page performance as well as your server storage. I recommend you to lower the file size limitation in AdminCP.
Originally posted by peterdrew View PostHI Glenn, are you still supporting this Mod?
thanks
peteHelpful? Donate. Thanks!
