I suspect this would be a huge benefit for those on a shared server.
I have a site on a dedicated VPS and notice a dramatic improvement to memory size whenever I clear system cache manually, about 8% when I clear it weekly.
It doesn't matter if you use Memcache or not. If you find yourself consistently clearing system cache manually for whatever reason, then you might need this mod.
We used Memcache and it worked well for a year. Then we moved to another hosting site and within a week we were having constant issues. Nothing much changed other than moving to the new host. We were still running approximately the same amount of new content daily, approximately a thousand new posts daily, Memcache was set to do exactly what it was set to do prior, yet we received notices from the new company daily and we had to hand-use Memcache daily. We saw some good reviews on this mod and decided to give it a shot. Best decision we could have made. No more memory issues. No more notices from the new hosting company.
I am a happy camper, as is is my forum. I don't think anyone can go wrong using this mod. It's a huge asset for a very small price. FWIW
Thanks for the nice review of this mod, -merzi! I'm glad this mod helps your forum!
Bought.
It really helps.
Thank you!
Some information:
This mod helps me to fix some error on my forum., it happens on this forum too.
The search module, at some point in time when clicking on a link (recent posts) produced an error - the search time is expired.
Earlier, clearing the cache once a day solved this problem, now cleaning is performed automatically by this mod once an hour, that completely solves this trouble.
Thinking about buying this. But with Glenn no longer offering install and customer support...im skeptical. What was the process for install? Does it require any work in the cpanel?
No, it doesn't work in vB6. The online/offline status icon has changed to Font Awesome icon in vB6 and the HTML and CSS classes have changed as well....
