Sticky topic background?
Originally posted by willie53 View Postadmincp/styles/style manager/Style Variable Editor/Sticky_topic_background_color
And all the topics are of the same color (background)
Originally posted by willie53 View PostTry and remove this from additional.css
Code:topic-list-container .topic-list .topic-item.sticky { background: #FFFFCC; }
Originally posted by willie53 View Posthere is the result you will get using the stylevar above of course you would use a different color
Originally posted by mito22 View Post
Ok but now.... I've lost the unsticky topics background... link at arrow.... before mod....
How can use style var? Is on VB5?- Go into admincp
- Select Styles
- Then Style Manager
- On the right hand side where it says Choose Action click the little down arrow and about half way down you will see Style Variable Editor click this from there you can search for sticky this will only show the stylevar Sticky_topic_background_color
- Click this and you will be able to select the color you want
Originally posted by willie53 View Post- Go into admincp
- Select Styles
by rdanI have multiple vBulletin 3 and 4 Licenses available for sale...
vBulletin 3.x
For the vBulletin 3.x Forum Licenses, some are standalone...Yesterday, 08:30 PM -
by MitchOn the unread, is there a way to have this option listed?
https://www.vintagefordforum.com/unread...Yesterday, 04:24 PM -
Get Affordable and Fast VPS for vBulletin
