Blogs page is not working
This topic is closed.
    Hello,
    I recently imported the blogs, but there seems to be a issue with the blogs page. I am thinking it is related to the date format that i uploaded, but i might be wrong.
    This is the error i am getting:
    Database error in vBulletin 4.2.5:
    Invalid SQL:
    SELECT COUNT(*) AS total,
    FROM_UNIXTIME(dateline - 3600, '%c-%e-%Y') AS period
    FROM blog AS blog
    WHERE state IN('visible', 'moderation', 'deleted') AND dateline >= 1514073600 AND dateline < 1515672964
    GROUP BY period
    ) UNION (
    FROM blog AS blog
    WHERE blog.userid IN () AND dateline >= 1514073600 AND dateline < 1517702400
    GROUP BY period
    MySQL Error : You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ') AND dateline >= 1514073600 AND dateline < 1517702400
    GROUP BY period
    )' at line 12
    Error Number : 1064
    Request Date : Thursday, January 11th 2018 @ 01:16:04 PM
    Error Date : Thursday, January 11th 2018 @ 01:16:04 PM
    Script : http://localhost/motortopia/blog.php?do=bloglist
    Referrer : http://localhost/motortopia/forum.php
    Classname : vB_Database_MySQLi
    MySQL Version : 10.1.29-MariaDB
    And this is the php warning at the top of the page:
    PHP Warning: mysqli_query(): (42000/1064): You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ') AND dateline >= 1514073600 AND dateline < 1517702400 GROUP BY period )' at line 12 in ..../includes/class_core.php on line 1386
    Any help is highly appreciated.
    Thank you!
    The list of userids is missing.
    You need to be logged in to view the code. Login or Register now!
    Where did you import the blogs from and how did you import them?
      Hello glennrocksvb ,
      Thank you for helping me out. I am importing from a custom built forum based on CodeIgniter, and right now i am in the process of ending the data migration.
      Thanks to you i looked carefully in the datbase, and noticed that i added some worng values in table called blog_user. That is why the blog page was giving errors.
      This step is now fixed.
      Do i need to close this thread now?
      I will post more questions in this forum for sure, as i still need to migrate all files, and connect them.
      Thank you once again!
        Glad to help. Will close this topic.
