Does anyone know how to enforce https on a Windows server? It seems Linux systems can just add code the htaccess file but the process differs for Windows.
Forcing the use of HTTPS:// on your site
In your web.config insert the followng code
Code:<rule name="HTTP to HTTPS redirect" stopProcessing="true"> <match url="(.*)" /> <conditions> <add input="{HTTPS}" pattern="off" ignoreCase="true" /> </conditions> <action type="Redirect" redirectType="Found" url="https://{HTTP_HOST}/{R:1}" /> </rule>
I tried the following in core/includes but it still shows unsecured content:
Code:<!-- This file is for IIS to block direct access to this directory to the webserver. This will not affect Apache (which has similar rules in the .htaccess file in this directory --> <?xml version="1.0" encoding="UTF-8"?> <configuration> <system.webServer> <rewrite> <rules> <rule name="HTTP to HTTPS redirect" stopProcessing="true"> <match url="(.*)" /> <conditions> <add input="{HTTPS}" pattern="off" ignoreCase="true" /> </conditions> <action type="Redirect" redirectType="Found" url="https://{HTTP_HOST}/{R:1}" /> </rule> </rules> </rewrite> <handlers> <add name="Deny" path="*" verb="*" type="System.Web.HttpForbiddenHandler" /> </handlers> </system.webServer> </configuration>
I believe it should be in web.config file in the vB root directory.Helpful? Donate. Thanks!
yes it will make sure all images has https instead of http
Then try to find the images causing the the lock at the address bar not turning green saying it is secure is to click on the lock the go to more information select media this will show the image that is causing the problemWise men say nothing Fools never listen
For user-generated content, it is inevitable that users would link to images using http and that will cause mixed content warning. To prevent that, you can block all mixed content
Reply to Topic Starter Ribbon for vBCloudby glennrocksvbThanks for reporting. I'll bookmark this post and check the issue.04-22-2024, 06:40 PM
