I'd like to add an accordion effect to <li> elements in topics or a static html module. Any idea how this could be accomplished?
Accordion effect
How do you exactly want to add an accordion effect to the list of topics?Helpful? Donate. Thanks!
When do you exactly want the effect to apply? What do you have to click to trigger the accordion effect? Your post lacks details to figure out the solution to the problem.Helpful? Donate. Thanks!
Just wanted to see if this would work in a static html module. I tried putting css and html in the static html module but it broke the entire page and I had to Disable PHP, Static HTML, and Ad Module rendering to remove the module.
I'm testing it now but not sure if I can add javascript to the module.
Glad you figured it out. You can add anything in a static html module. Just don't add <html>, <head> and <body> tags as they are already on the page.Helpful? Donate. Thanks!
Reply to Topic Starter Ribbon for vBCloudby glennrocksvbThanks for reporting. I'll bookmark this post and check the issue.Yesterday, 06:40 PM
Reply to Topic Starter Ribbon for vBCloudby MitchIt seems since the 6.0.4 update the topic starter is no longer workingYesterday, 05:02 PM
