We are getting feedback that our forum's logo and header banner only appears when a user is logged into the site. Is there a setting in AdminCP that I can update so the logo and header banner always appear whether logged in or not or would this be a custom CSS solution? We're using vBCloud. Thank you.
Logo/Header Banner doesn't appear when not logged in
Can you post a link to your forum?Helpful? Donate. Thanks!
That looks like a permission issue. To avoid having such issue on site logo, I recommend just uploading your logo image directly to the server using the vBCloud File Manager in AdminCP. Then copy the generated URL of the uploaded logo. Then go to Style Variable Editor, search for titleimage style variable and paste the copied URL and save. Repeat updating the style variable for each active theme/style your site is using.Helpful? Donate. Thanks!
by rdanI have multiple vBulletin 3 and 4 Licenses available for sale...
vBulletin 3.x
For the vBulletin 3.x Forum Licenses, some are standalone...Yesterday, 08:30 PM -
by MitchOn the unread, is there a way to have this option listed?
https://www.vintagefordforum.com/unread...Yesterday, 04:24 PM
