Some strange behaviour
    While trying to share a post on facebook i got some very strange behaviour more than likely caused by google maps it looks funny when you see it.
    That's strange. If you remove Google map, does it not happen?
      Just found out it is not google maps it may be a clashing mod that i installed i created a vanilla site on test server and works fine on that then started installing the mods i have on live site still not found the one that caused it but rulled out all mods from here
        Glad to hear that it is not caused by any mods here.
      OK i have closed 1 site down and used a different site to install vb5 without any mods well maybe a few css mods from here i still have a spare licience i can use once i sort this out
        Could it be caused by a browser plugin? Is it consistently happening in just one browser or all browsers? That's where I would start looking.
          It is now fixed problem was if you were facebook connected this caused the strange behaviour
            That's strange. Is this a vB or FB issue? Is there something that vB can do to fix the issue or should Facebook fix this?
              it may be facebook any way i have left a bug report here http://tracker.vbulletin.com/browse/VBV-16878 lets see what they make of it
              it was working fine with facebook connect turned on but started acting strange once i started using google maps on the events
              • nekro711
                New here
                by nekro711
                Hello guys,
                Im new in this vbulletin thing and while i googled for some info i found this forum.
                Yesterday, 04:12 PM
              • Kubes
                Reply to New here
                by Kubes
                Welcome i am learning too. What version you running? I just upgraded to 6.0.3
                Yesterday, 04:45 PM
              • MikeSD
                Hi, I'm starting over
                by MikeSD
                My web host went out of business after nearly 20 years. I had to do backups of all my Forums to a new site. That's when I started having problems....
                Yesterday, 03:57 AM
