I use a 70 / 30 layout and would like to add a module on the 30 side that rotates random images. I read about using php to accomplish this, but is there an easier way for non-technical users?
Rotating Banner
You can use pure Javascript to do it. You just have to hardcode in the script the URLs of all the possible images you want to display.
See below sample script I just did for you. You can use a Static HTML module for this.
HTML Code:<img id="rotateImage" src="https://vbmods.rocks/filedata/fetch?id=6967&d=1508057154" /> <script> (function() { var bannerImages = [ "https://vbmods.rocks/filedata/fetch?id=6967&d=1508057154", "https://vbmods.rocks/filedata/fetch?id=6964&d=1508045443", "https://vbmods.rocks/filedata/fetch?id=6968&d=1508057279" /* no trailing comma at the last element */ ], image = document.getElementById('rotateImage'); function rotateImage() { var index = Math.floor(Math.random() * bannerImages.length); image.src = bannerImages[index]; } window.setInterval(rotateImage, 1000); //1000 (msec) = 1 sec (adjust as needed) })(); </script>
What I showed you was a just a simple rotating banner script that I quickly created as a kind of prototype. If you want a full-featured script, then you'd have to find one or use the one that the Content Slider module uses which is https://www.jssor.com. But it will not be easy for non-technical users to implement.Helpful? Donate. Thanks!
I can't seem to get it to work with linked images. Why doesn't it work by pre-populating the link in bannerImages?
<img id="rotateImage" src="http://mysite.com' target="_blank"><img src='https://mysite.com/fa2559af99820075c7b8" />
<script>
(function() {
"<a href = "http://mysite.com' target="_blank"><img src="https://mysite.com/fa2559af99820075c7b8"></a>",
"<a href = "http://mysite.com/help" target="_blank"><img src="https://mysite.com/46c7969d548125d7e658"></a>",
</script>
I created a simple rotating banner script at https://vbmods.rocks/forum/vbulletin...-banner-scriptHelpful? Donate. Thanks!
Reply to Topic Starter Ribbon for vBCloudby glennrocksvbThanks for reporting. I'll bookmark this post and check the issue.04-22-2024, 06:40 PM
