How did you get your notification bubble to pulsate like that? CSS3 again? Is that a mod you have here?
How to pulsate notification bubble?
Last edited by glennrocksvb; 09-07-2017, 11:49 AM. Reason: Removed unrelated quote from original postTags: None
Yes using CSS3 animation. I'll post the code shortly.Helpful? Donate. Thanks!
Hard to implement. But easy to install, just copy and paste.Helpful? Donate. Thanks!
Fleet, I moved your post into a new topic as it is unrelated to the Topic Starter Ribbon mod.Helpful? Donate. Thanks!
Im pretty excited about this little upgrade. You know how much i hated the notification text. The icons are so much better. The pulsating bubble will give it some depth as well. Be really impressive to have a hover that actually drops down the list of notifications. But that has to be difficult to do.
Fleet, here you go...
by rdanI have multiple vBulletin 3 and 4 Licenses available for sale...
vBulletin 3.x
For the vBulletin 3.x Forum Licenses, some are standalone...Yesterday, 08:30 PM -
by MitchOn the unread, is there a way to have this option listed?
https://www.vintagefordforum.com/unread...Yesterday, 04:24 PM
