Good aversi can help me in this, I need to know how to make the user program runs automatically by the system without having to wait every hour thanks.
Scheduled Tasks promotions users
If it runs every hour now, you did already changes. I think default is 25 minutes to promote users by scheduled tasks.
You can change the time in admincp => scheduled tasks => scheduled task manager => User Promotions => edit.
You could also run it manually from there.
But I don't know how it increase serverload if /includes/cron/promotion.php runs often.
Hope I got your question right and thats help you?My forum closed !
Originally posted by delicjous View PostIf it runs every hour now, you did already changes. I think default is 25 minutes to promote users by scheduled tasks.
If I saw the option to change, I'm not clear if it's in the 25th minute of the hour and then it takes another hour until the 25th minute of the next hour, I do not know myself, I put it every minute, According to law out there the user must be active for some time. I think in my case the problem may be that I am with 2 accounts doing test from the same ip. Thanks for your answer to see if anyone knows how to modify php and clarifies more.
t is for example like this forum, When you confirm the mail, another notice comes out to create a new theme, and I understand that this is done with promotions of groups of users,1 Photo
The promotion of email verification isn't done by that schedule I think. It is calling the api and promote the user directly (not 100% sure but I could not imagine it is done by schedule).My forum closed !
Senior Member
- Aug 2017
- 113
- 11
- 56
- "Life is what happens while we make plans.
John Lennon.Thank you very much @glennrocksvb for your dedication to the users of this forum" - Male
- Spain [ES]
You are right. The moment you verified your email, your usergroup will be updated immediately.
A cordial greeting
You can adjust the run time of the user promotion scheduled task to make it more frequent. But note the execution may still not be on time due to the following factors.- There should be active users visiting your site. The scheduled tasks are automatically triggered when a page on the forum is loaded by a user.
- There may be other scheduled tasks ahead of the user promotion task in the queue. So even if it's time for the promotion task to run, it may take several page loads by users before it actually runs.
- Likes 2
It may be that if I am doing the test from the same ip so do not upgrade and apply the promotion, although I am with different browsers but same pc thanks
As you load the page on your site, watch and reload the Scheduled Task Manager page in AdminCP to see that the task at the top of the queue is taken off the top IF that task is scheduled to run. Repeat the process until you see User Promotion task is executed.
Solved many thanks, I will continue to ask about this forum on other issues
by rdanI have multiple vBulletin 3 and 4 Licenses available for sale...
vBulletin 3.x
For the vBulletin 3.x Forum Licenses, some are standalone...Yesterday, 08:30 PM -
by MitchOn the unread, is there a way to have this option listed?
https://www.vintagefordforum.com/unread...Yesterday, 04:24 PM
