Is there a way to ease the corners of the body layout so it isn't so much of a box style?Kinda like the corners on this sites logo. I would be nice to ease the corners of the forum body as well.
Soften the corners
Can you post a screenshot marking exactly which corners you were referring to?Helpful? Donate. Thanks!
PHP Code:#channel-tabbar .channel-tabbar-list li.current a, #channel-tabbar .channel-tabbar-list li.current a:hover, .edit-mode #channel-tabbar .channel-tabbar-list li.current a:hover {
border-radius: 15px 0px 0px 0px !important;
#channel-tabbar {
border-radius: 15px 15px 0px 0px !important;
.search-container .search-box {
margin-right: 5px;
Here's what it looks like with the above implemented: https://s10.postimg.org/6xo9ma0c9/Thelodge.jpg
Enjoy,
William
Here's my solution:
Code:.l-desktop #channel-tabbar .channel-tabbar-list li:first-child a { border-radius: 8px 0 0 0; } .l-desktop #channel-tabbar { border-radius: 8px 8px 0 0; } .l-desktop #footer { background: transparent; } .l-desktop #footer-tabbar { border-radius: 0 0 8px 8px; }
For the upper left corner, you only apply the rounded corner in the first menu item (regardless if it's the currently selected or not). Let's say the the currently selected menu item is not the first item (e.g. Blogs), then you don't want to apply rounded corner to it.Last edited by glennrocksvb; 06-03-2017, 10:49 PM.Helpful? Donate. Thanks!
- Likes 2
Try this:
Code:#footer { border-radius: 0 0 5px 5px; }
Thank you!
A little something coming your way.
I noticed on the initial css code it is included but the name is different, therefore it must have changed with previous versions of vB that is why it didn't work?
All set now, again thanks!
