Hi there,
I was just wondering if it is very difficult to add a template to forum style. I donΒ΄t like the way blog posts are shown. And I would like to add the look of the blog itself.
So when you visit a member blog it looks like this: https://vbmods.rocks/blogs/vbulletin-5-tips-and-tricks
But when you open a blog entry, then the info about blog itself is gone... see here: https://vbmods.rocks/blogs/vbulletin...ning-the-topic
Normally you could easy create a new template via site editor. But the blog module is not available there
Also its not possible to go the other way round: Use the "Default Blog template" and create a new one because also the conversation mod is not available in side editor.
Does anybody has an idea or turorial to create a template for blog conversations?
