This isn't a modification request. It's a question regarding how to link back to the forum home page when a user clicks on the logo. This forum logo links back to vbmods.rocks when you click on it, but on my forum when you click the logo you're taken to the image. I'm sorry if this is in the wrong place and if I'm even allowed to ask this here but if anyone can help I'd really appreciate it. Thank you.
Header/logo link
Did you modify the "header" template and change the logo URL?Helpful? Donate. Thanks!
In header template search for the following around line 306
PHP Code:<a href="{vb:raw baseurl}/"><img src="{vb:stylevar titleimage}" data-orig-src="{vb:stylevar titleimage}" alt="{vb:phrase logo}" title="{vb:phrase powered_by_vbulletin_title}" /></a>
Change {vb:raw baseurl}/ to your desired url.
You don't actually need to edit the url in the header template if you want the logo to link to the homepage which the default header template does.Helpful? Donate. Thanks!
Originally posted by William View PostIn header template search for the following around line 306
The default code for the logo in the header is actually:
Code:<div class="site-logo header-edit-box"> <a href="[COLOR=#FF0000]<vb:if condition="$vboptions['titleimageurl']">[/COLOR][COLOR=#0000FF]{vb:raw vboptions.titleimageurl}[/COLOR][COLOR=#FF0000]<vb:else />[/COLOR][COLOR=#0000FF]{vb:raw baseurl}[/COLOR][COLOR=#FF0000]/</vb:if>[/COLOR]"><img src="{vb:stylevar titleimage}" data-orig-src="{vb:stylevar titleimage}" alt="{vb:phrase logo}" title="{vb:phrase powered_by_vbulletin_title}" /></a> </div>
You don't have to change anything in that template. Maybe you've set titleimageurl option somewhere in AdminCP? I don't know what and where that option is.Helpful? Donate. Thanks!
Originally posted by glennrocksvb View PostThe default code for the logo in the header is actually:
That's it! The Header Logo URL.Helpful? Donate. Thanks!
Reply to Topic Starter Ribbon for vBCloudby glennrocksvbThanks for reporting. I'll bookmark this post and check the issue.04-22-2024, 06:40 PM
