Php 7.2 ising IIS
    Php 7.2 ising IIS
    Is anyone here using php 7.2 with IIS?
    curious if so have you had any issues?
    I believe rnedelkow is using IIS. But not sure if he is using PHP 7.2.
      I'm running PHP 5.6 on IIS without any issues.
        I'm at 7.0.9 and contemplating 7.2
          PHP 5.6 is no longer actively supported by PHP group. This means that bugs are no longer being fixed. Security support will end on Dec 31st, 2018. This means that only critical security issues will be fixed within that period. After that, then no bugs and security issues will be fixed.
          More info on supported versions at http://php.net/supported-versions.php
