module size problem
    module size problem
    I have added a new page to my forum so I can add brochure covers with direct links to pdf files online. When I add the html modules to the page the first one is a different size. I have made sure all the images are the same size etc. Why would the first module be slightly bigger. It's my ocd I want them all the same size lol
    You can see here the first module is slightly taller !
    The width of each column has size of 33.333333333%. For some reason, the width of the first one is wider than the other two. That causes the image in the first column to be taller.
      Them images I used are all exactly the same size as I thought that might have been the issue.
        I have tried to reduce the width of the image for the first column but its still the same
          The image anchor links has missing </a> tag. Not sure if this would fix the issue but anchor tags should always be properly closed.
          Here's what you have. Notice the missing </a> tag at the end.
          <a rel="nofollow" href="https://www.dropbox.com/s/u6t2zs6rypy4cx2/RenaultSport%20Range%20November%202015.pdf?dl=0">
             <img src="https://i.imgur.com/BMmMXEG.jpg">
          It should be:
          </a>
            For SEO benefits, <img> tags should have alt text to describe what the image is.
            <img src="https://i.imgur.com/BMmMXEG.jpg" alt="Renaultsport - Reignite your Va Va Voom" />
              Thanks Glenn, really appreciate you looking at this. I added the tag at the end but its still the same. Do you think its an issue with vbulletin where the size of the first column is wrong ?
                My Video wall page is fine, very strange
