Did you mean external links and not internal? Normally you would add nofollow to external links not internal links? But if you want some of the pages on your site to be nofollowed, then just block those pages in robots.txt so that they will not be crawled by search engines.
βRel=βnofollowβ means the PageRank wonβt flow through that link as far as discovering the link, PageRank computation and all that sort of stuff,β Cutts said. βSo for internal links, links within your site, I would try to leave the nofollow off.
βSo if itβs a link from one page on your site to another page on your site, you want that featuring to flow, you want Googlebot to be able to find that page,β Cutts continued. βSo almost every link within your site, that is a link going from one page on your site to another page on your site, I would make sure the PageRank does flow which would mean leaving off the nofollow.β
But to add nofollow on external links, go to AdminCP > Settings > Options > BB Code Settings > Add nofollow attribute to URL BB Code and set it to Yes.
