i am reinstalling over 5 times and same error did i miss something
installation stuck at 72% step 13
its stuck at 72% step 15
Click the Show Details button and post the content here.
its stuck here :
Step 15 - Importing vbulletin-style.xml
Template Group: Admin
Template Group: Article
Template Group: BB Code
Template Group: Blog
Template Group: Blog Admin
Template Group: Color
Template Group: Content Entry
Template Group: Conversation
Template Group: CSS
Template Group: Dialog
Template Group: Display
Template Group: Editor
Template Group: Error
Template Group: Group
Template Group: Human Verification
Template Group: Inline Moderation
Template Group: Link
Try reloading the page and it will pick up where it left off. Keep doing it until it's finished.
Wait, if you're not getting any error then you should just wait for it to be unstuck. How long have you been waiting?
Also check the browser console (press F12) for any JavaScript error.Helpful? Donate. Thanks!
Well, with the information provided there's nothing we can do unless we get access and see the issue ourselves. Did you report it to vB support forum?Helpful? Donate. Thanks!
