<b>Member</b> title html showing
    What would cause the html to show on user titles such as what you see in the thread title?
    It is not consistent with all users on the forum, odd. Its v5.4.0
    Link?
      i am not sure i thinking you have to give permission "Advance Editor" to all member group or all register user
      i have to look on my forum see if i can found
        Here is the link to one of the profiles that displays wrong. http://www.adkhighpeaks.com/forums/m...5828-spencervt
          No guest access
            I don't fully understand your response Glenn, Sorry.
              I can't see the topic. Not authorized to view the page.
                Here is the post; http://www.adkhighpeaks.com/forums/f...new-2018-route
                He is post #8
                  advance option do you mean this?
                    Is this a Custom User Title or a Rank? If it's a Custom User Title my guess is it doesn't work if a member is not allowed to use HTML. In case it's a rank maybe running Update User Titles and Ranks will fix this issue.
                      hi you can give permission to member if you want don't need have a title
                      you have to give the permission on Channel Permissions Manager then all member will have html option believe there is a risk you have to know if you can trust all member
                        Thanks all.
                        It was a case of user allowed to use custom title, but not html.
                        Rebuilt the user titles as well.
                          hi NumNum done a test on my test forum look it on admin panel to
                          Rebuilt the user titles cannot found on panel
                          found running Update User Titles and Ranks din't fix
                          • NumNum
                            NumNum commented
                            It didn't do anything specific for this issue for me either. It was the user setting to use custom title with no html permission. I revoked his access to use custom title since he wasn't using a custom one to begin with.
                        • Kubes
                          Reply to New here
                          by Kubes
                          Welcome i am learning too. What version you running? I just upgraded to 6.0.3
                          Yesterday, 04:45 PM
                        • nekro711
                          New here
                          by nekro711
                          Hello guys,
                          Im new in this vbulletin thing and while i googled for some info i found this forum.
                          Yesterday, 04:12 PM
                        • MikeSD
                          Hi, I'm starting over
                          by MikeSD
                          My web host went out of business after nearly 20 years. I had to do backups of all my Forums to a new site. That's when I started having problems....
                          Yesterday, 03:57 AM
