Hi, i am looking a mod wich sets blue "bricks" in postbit. Where i can find it?
mod of "blue bricks"
This is a stylevar setting postbit _background
you will need to download the transparent background image from here click in the search window and from the dropdown menu select wall you will see one called brick wall download this one then upload it to the server usually in the images directory remember where you uploaded it to and the filename then edit the stylevar postbit _background of the theme you want to use to some like below
with a result like this
by mbrmbrAs the title states, would you consider creating a mod that removes single post links from the home page? This would be for SEO purposes, search engines...Yesterday, 01:20 PM
