Hi Guys,
Got a bit of a weird issue starting on a freshly installed vBulletin.
I go about adding my Forums & Categories, I've changed the Unregistered users to not be able to see anything unless they register.
I've added a few new titles as well.
Again, everything was working fine and then after a few hours, I get the below. A System Error has occured.
The software is experiencing a systems error.
You should attempt to repeat your last action. If this error occurs again, please contact the site administrator.
I have no third party plugins installed, the forum is completely standard apart from the changes I mentioned above.
Any one able to assist please?
Thanks!
Thanks!
