Quote box is not appearing in posts
    I've recently installed the latest version of vBulletin. To this point all I've done is change colors on the board. I have not installed any mods. When quoting a users post, the quote box is not appearing in the post. It shows in the preview window prior to submitting, but not in the final post. Any suggestions where to look for a fix?
    First of all, welcome to vbmods.rocks!
    Check if bbcode_quote template in Style Manager in AdminCP exists. It might be missing for some reason.
      I do not see bbcode_quote. The following codes are present.
      bbcode_code_background
      bbcode_code_border
      bbcode_code_fontsize
      ​​​​​​​bbcode_code_line_height
      ​​​​​​​bbcode_quote_background
        You seem to be looking in the stylevars not templates.
          Yep. Your right. I found it in templates where it should be. Now what?
            Is it modified? You can tell if template name is red. If yes, revert it. Backup first before reverting. If no, then check if all bbcodes and not just quotes are not working? This might be due to bbcode permissions in the channel.
              It’s definitely not modified. The only thing that has happened is I rebuilt all my channels. As far as I can tell everything is working but quotes.
                After contacting vBulletin support my issue has been resolved. It turns out that I had censored the word ***, which was apparently breaking my site. I put {} around the word and that corrected the issue. Weird!
                  Glad it's fixed.
                  • nekro711
                    New here
                    by nekro711
                    Hello guys,
                    Im new in this vbulletin thing and while i googled for some info i found this forum.
                    Yesterday, 04:12 PM
                  • Kubes
                    Reply to New here
                    by Kubes
                    Welcome i am learning too. What version you running? I just upgraded to 6.0.3
                    Yesterday, 04:45 PM
                  • MikeSD
                    Hi, I'm starting over
                    by MikeSD
                    My web host went out of business after nearly 20 years. I had to do backups of all my Forums to a new site. That's when I started having problems....
                    Yesterday, 03:57 AM
