vB4 - Make replies unreadable for Guests to encourage signups
    Paid Mod vB4 - Make replies unreadable for Guests to encourage signups
    One way to encourage signups for your vBulletin forum is to blur out replies for guests in such a way that only the starter post is visible and the replies are unreadable. This is the vB4 version of the original blur replies mod for vB5.
    Instructions:
    Please refer to the installation document included in the download file.
    Disclaimer:
    The solution used here is using CSS. This means that web-savvy users might be able to figure out how to bypass it and be able to obtain the content. But for normal users, this would be enough deterrent for them and would encourage them to likely signup to your forum to obtain access to the content.
    Price: $10
    Screenshot:
    Can i limit this affect on specific forums? or it will work on all forums? Because i just need this affect on 1-2 forums of my web, not all forums.
      Good question QuachVu. Right now, it applies to all forums. I will check if it's possible to update this mod to work for selected forums.
        glennrocksvb super, just let me know when you have done. I will buy it
          hi. how do i apply to "awaiting email comfirmation" group?
            What did you mean? After registering, you will be automatically moved to Awaiting Email Confirmation usergroup.
          hi, mean this unreadable also to awaiting comfirmation usergroup. Cause right now, after user register, but still under awaiting comfirmation usergroup. after they can read, their dont vist the activation link.
          Which mean i can use any fake email to register and view the replies without activation . u got it?
            Ok, I got it. I will check if that is possible.
          Can I apply for the first topic instead of the replies? Because in my forum the first topic is the most important !
